Arlo Pro. Can I log into the account from two or three different sources at same time?
  • 2 Replies
  • 3922 Views
  • 2 Likes
Welp
I just installed two arlo pro cameras outside. When I was logged in at one point, it logged me off and said somebody else logged in. I gave my wife the password and whatnot. Does she need to create her own account and password, or can we both be logged in under mine at the same time? Thanks
Problem is, ONLY one primary user device can be logged in at a time....
You can grant your wife almost full access , which will not bump u off, using GRANT ACCESS in the settings...this will be her own email/password
Welp
That helps, thx. Just didn't know if she needed her own sign in info. I invited her and granted her access now and that seems to have solved the problem.
