Arlo Pro Camera - missing charging pin / metal spring inside to make contact with battery fell out.
One of the 3 little prongs/springs fell out from the inside of the camera when I was cleaning it. Now the battery won't make contact or turn on the camera (of 4 contact points). How can I repair this? solder, find a replacement? rig something to the connector?
You would need to replace the camera. There is no replacement parts for this.
