Arlo Pro Camera battery drain 12 hours. Faulty Camera?
I have a problem with 1 of my 3 camera's, first of all it wont charge directly on the camera I need to use a battery charger. When its fully charged it lasts about 12 hours even if there is zero motion activity on the camera.
Its not the battery, I swapped them around but this camera still has the same problem.
If I turn the camera on in live mode there is a clicking noise coming through on the audio.
My cameras do have a silicone cover but I'm thinking some sort of short or weather damage, any suggestions?
thanks
Swap batteries to confirm that it isn't just the battery. If still an issue,
Contact Arlo Support for possible warranty issue.
Yep I've tried a battery swap, it drains the order one too.
I'll probably be out of luck with the warranty, its 16 Months old.
.....also today instead of putting it back outside I've left it on my desk with a full battery charge, its really hot, that must indicate a fault with it.
