Arlo Pro Camera VMC4030 No Lights On Camera & Not Syncing
Hi, (First of all, I speak spanish so I´m sorry for my english) I have an issue, one of my cameras ran out of battery, so I charged it and turn it on and it said that I had to upgrade a firmware , I tried several times and it always said that the camera didn´t allowed the upgrade, then I had a message that the camera wasn´t connected to internet and I had to contact support.., So I read that some people had the same issue and just erased the camera and sync it again.. I did the same thing, but the problem was that the camera when I push the sync button didn´t have any light,s, I tried with other batteries and nothing, I plug it to the wall and a blue light flashes pretty fast and then after 3 seconds the light turned off, and when is fully charged it gives me a solid blue light, I have tried taken the battery off a couple of times, and try to push the sync button for 2 seconds and nothing. any ideas?? simple
You want to only briefly press the sync button on the camera and the blue LED should start flashing slowly
When I try to charge the camera battery the bue ight comes on for a second and then goes out. I have left the camera on the charger over night but never get the solid blue light indicating the battery is charged. I tried syncing the camera with the bas station but don't get any lights on the camera at all.
Didn´t work for me... I´ve tried briefly press the button, quick press, several times but nothing.
Hi patf9033,
Have you tried to remove the camera and re sync it?
Hi PabloFM,
What are the LEDs displayed on the base station? You should have a green power & internet light Arlo Support What do the LEDs on my Arlo or Arlo Pro base station mean?
@patf9033 wrote:
When I try to charge the camera battery the bue ight comes. on for a second and then goes out. I have left the camera on the charger over night but never get the solid blue light indicating the battery is charged. I tried syncing the camera with the bas station but don't get any lights on the camera at all.
Do you get a charging indication for the camera on either the app or a browser while it's plugged in? It should be the battery icon with a lightning bolt in it. If not, remove the battery and plug it in - any better? If not, it sounds like the camera has an issue.
