Arlo Pro Base station battery backup
  • 1 Reply
  • 3859 Views
ArloProG
Hi,
I'm looking to set up a backup battery for my Arlo base station just in case the power goes down. How do I set it up? Thanks for your help!
Buy a UPS and plug the base into it....problem solved
Tho I do recommend also plugging in the router and modem.
