Arlo Pro Base station Wifi Ap configuration/Password
Hi,
Recently we ahve Cyclone in Chennai, India and No Internet worked for weeks during this period we tried to connect the base as Access Point to view camera but as the base is password protected we could not able to connect. My question is camera is connected to base via Wifi and if we could able to connect base locally using Access point concept and connect the camera through it to view the status it will be helpful in our situvation kindly help.
Did you mean i need to connect my mobile's internet in Hotspot or i can connect my Wifi Modem to base via ethernet cable and view camera using the Wifi Local Modem Hotspot? if so tell me the procedures.
Thanks in Advance
The Arlo base will set up it's own wifi network for the cameras ONLY, you can not acess it with any other device.
The Arlo base needs and ethernet port to function as it needs internet access.... If your wifi hotspot has one then the base would connect there.
If the hotspot does not, then you will need a wifi extender that 1) hooks into your hotspot 2) has an ethernet port ( the base will plug into the extender then )
You will acces the camera system thru your normal wifi from the hotspot.
Hi
I tried but it does't worked i thing the local hotspot need Internet. Without Internet this system will not work.
Kindly confirm.
Cheers
Anbumani.G
Correct. The hotspot is to provide the Internet access. Without it Arlo won't work.
