Arlo Pro Base Station plugged directly to hot wall jack or directly into router?
Can the base station be plugged directly into a “hot” wall jack instead of directly into the router?
depwnds on what you mean by "hot wall jack"...
If it's etherent wired thru the home and goes to a router for internet, then yes
