Arlo Pro Base Station does not want to power up
My base lost power after 6 months. Changed her power AC adapter compatible with Arlo, still no power. Model is 4R047AGA392F. Any suggestions
If you are sure the power supply is good ( 12v DC center positive ), then the base may have an issue...
contact Arlo support for possible warranty
What are the LEDs on the base showing?
No they’re not
sounds DOA
