Arlo Pro Bandwidth Usage Internet Slow
Hi.
I've installed my new Arlo Pro with 2 cameras a few days ago. I have noticed that internet is very slow since then. My base is armed but video is recorded only if audio is detected. There are not a lot of those recorded.
What could be causing that?
Thaks
-- Eran
Test your Internet speeds using speedtest.net. Try it both with Arlo working and with it disconnected/turned off to see if there's a difference. Are you subscribing to CVR?
ALso, try rebooting your router.
No CVR.
No big change on speed when system is connected.
I rebooted Arlo and so far it's OK.
Thanks.
Thanks.
