Arlo Pro Android app changing finger print for login
  • 2 Replies
  • 1579 Views
Wendy_B
Hi, the finger I use for login has been damaged and I would like to change the finger print that I have registered on the app, but I can't see a way of doing this, only of switching finger print off.  Any advice would be appreciated - thanks. Wendy
On the S7 android, doesn't the PHONE control the finger used ?  I have two fingers registered and both work with the app signin. ( check the phone setttings )
Wendy_B
Brilliant! - yes! you are absolutely right 🙂 Thanks very much for something I feel I should have known, but now I do.
Thanks, Wendy
