Arlo Pro All Lights Are Green But Will Not Show Up Under Devices
All lights are green on base station but when i go to add devices they will not appear online under "devices". I have reset, I have completed removed all devices and now that I'm trying to add them i can't. This is driving me crazy because it is one problem after another with these cameras. And all of my cameras show that they are connected but none of them will show under devices although ALL green lights are on base station.. PLEASE HELP!
After the reset, is your base showing up in the app? If not, you need to add the base before you can add the cameras and sync them. If so, have you logged into your system on a PC to see if you can add them there?
Brian
