Arlo Pro Add on Camera
  • 1 Reply
  • 2698 Views
cmr2payne
Hello
will a Arlo Pro add on camera purchased in the USA work in the UK ? Is the charger auto switching ?.
Many Thanks
Chris
The charger that came with my Pro has an input of 100-240vac...
If the prongs are correct for you it will prob work.
( or a Qualcomm dual V charger like for my S7 ( 5 and 9V output ), some compatable chargers work fine , some don't so you may have to test )
