  • 11 Replies
  • 6893 Views
LA-arlopro
We've had issues for 5 days now. The base is showing as disconnected, but yet I see three green lights and am writing this connected to the Internet. We've powered down, powered up, gathered all the Arlo Pro wireless cameras back in (recharged) and resynced (recharged) and things just haven't improved. Got any ideas as this is just no fun at all.
11 REPLIES 11
Streak2
Master Master
You have done all of the obvious things.
Next step would be to hit the remove device button of reach camera and then factory reset the base and resync the cameras.
https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-base-station-to-the-default-values
LA-arlopro
Sorry, I failed to mention I did those things but not necessarily in that order.
1. I did the factory reset (paperclip into the back), ran through the series of lights flashing until I got green.
2. Added my base back.
3. Removed all cameras, then added them back and re synced each.
So before I go through this long process again, I would like to clarify if your order is absolutely critical in which case....I will put in the time it takes to do it again.
Streak2
Master Master
I doubt changing the order will make a difference.
Have you tried restarting the device/router that the base is wired to?
Are you using an app or the web interface to access Arlo?
LA-arlopro
Glad you asked about restarting the router. I had disconnected the arlo base cable from the router, and also turned off and turned back on the router.
I am using the app.
Go to the web interface instead?
Streak2
Master Master
I dont believe it will make a difference but you can try here
https://arlo.netgear.com/#/login
What firmware version is running on the base? Mine is on 1.8.10.1_13433
How old is the system? Still under warranty?
LA-arlopro
The base is still showing as disconnected on the web.
I bought this system in January, 2017. How exactly do you check the firmware of the base when it is showing as disconnected?
Streak2
Master Master
You have tried pretty much everything. Looks like the base may have a problem.
See if the store you bought it from will exchange under warranty otherwise open a case with support in the link below.
LA-arlopro
Not really an option to return it to the store I bought it from (Best Buy - online, delivered to my inlaws in the US) as I do not live in the U.S.
So my next step is to open a case. You mentioned a link. There was no link.
Contact Support link at the bottom here.
LA-arlopro
No link, not even in invisible ink because I ran my mouse over the entire reply.
It's not in the reply, it's at the bottom of the page.
