This issue has been resolved in iOS app version 2.3.2 please visit the app store and update your Arlo mobile app to this latest version.
I had the same issue yesterday with my iPhone app. The iPad was fine. I just restared my phone and issue fixed.
Deffinately a system/ software glitch. There had been no changes to my system or phone.
This issue is currently under investigation by the engineering team. I will post an update as soon as I have more information. We appreciate your patience in this process.
This issue is still being investigated by the engineering team. Please do not attempt to remove the duplicate cameras as this does not resolve the issue. Some users have reported having success by uninstalling the Arlo mobile app and downloading a fresh version from the app store. I will post an update when I have more information.
We apologize for any inconvenience this may cause and thank you for your patience,
I had the same problem on my iPhone 5SE, one week ago.
I solved it by reinstalling the app (several times).
Until now (5 days) the trick worked.
I am still having the same issue since I installed the new version of the Arlo app.
Right now the camera that is in my garage ,which is connected to AC , is working fine. The only issue have with that one is a double picture/image while viewing it.
The second camera , which is located outdoor uses an Arlo rechargeable battery. Since the Arlo app version screwed up, I am not getting the real battery percentage. I had my battery charged 100% and after 2 days it will show 25% and then the next day , it will give me Camera is not connected (maybe seing it as no charges in the battery already) but I don't believe the battery is depleted. I just bought the Arlo Pro on Dec. 21st 2016.
Why can't you (Arlo tech) just give us option to download the previous app version while you guys are fixing this newer version. It is a security issue for most of us not having a reliable unit...
Thanks so much!
