Another person watching my arlo and can't log back in
So my ex girlfriend had my password to the arlo, ive changed it multiple times. So if she signs out, she cant get back in. The problem is, i cant force her to do that. Help!
If you log in with the Primary password on two devices, the second login will knock the first offline.
So log in , change your password , and then for the next girlfriend use Grant access which you can delete later if wanted
Or
Take down the account, remove all cameras and then base ( use remove device ) and bring back as new account with a new email/password
