All back to normal now?
If you get 3 green lights on your Base, Try logging in thru Web it works for me.. I'm using Safari.. I haven't tried on any other browsers yet.. Pass it on if it works..
Update: I think it's all working now.. For me at least using iOS..
Thankfully, my Arlo Pro Base station is up and running again.
Overall, I have been quite pleased with my set-up for the past year. This is the worst issue I have experience, thus far.
Good afternoon @hellobethie,
I am sorry to hear you are still experiencing issues with the Base Station appearing offline. I'd like to work with you directly to further isolate the issue.
Here is a tip! In some cases, customer's will attempt to factory reset the Base Station in an attempt to resolve the "Offline" error. If you have performed a factory reset I recommend performing the steps outline below to remove (remove Device) the base station and re-claim it.
Removing the Arlo Base Station:
- Log into Arlo account
- Click Settings
- Click My Devices
- Click the Arlo Base Station Icon (as shown below)
- Click Remove Device
Reclaiming Your Arlo Base Station:
- While still logged into your Arlo account click Devices Tab
- Click Add Device
- Follow the prompts.
For more information on adding the Arlo Base Station back to the account please visit: Can I add an additional Arlo device to my existing Arlo camera or system?
If you're willing to work with me directly please send me a private message with your contact information and I'll reach out to you promptly.
Best Regards,
ChristineT
____
Please click
KUDOS or REPLY if you found this helpful.
