Flash update errors
truckerh Aspirant
Did click the icon between padlock and i and it solved my problem that only appeared a few days ago.
That was an easy fix. Thank you
BobGauke Aspirant
I tried that "fix" and it worked well however I am finding that each time I log in to myarlo account and try live stream I have to apply this fix... somehow it is not saved. This is an annoyance but not the end of the world.
Model: VMB4500 | Arlo Pro/Pro2 Base Station
LincsDave Aspirant
Hi had same problem & fix not work for me on Edge or Firefox - no extra icons. Went to other browser BRAVE & following fix worked for me:
Click on padlock in address bar;
click on settings cog from drop down. You now get a whole page of settings; Look for Flash setting on right handside & reset permission to "allow".
Return to Arlo site YOU WILL NEED TO REFRESH PAGE to ALLOW Flash to work.
Click back on LIVE on camera link - hope this also works for you!
If you go back to the padlock in address bar after completing this change you will see the Allow Flash is now added at that point rather than going into all settings window.
Good luck folks.
LincsDave Aspirant
Good luck folks.
20UK Aspirant
SAFARI USERS
When you've updated Flash - go to VIEW, and down the menu you'll find 'RELOAD WITH PLUGINS' . . . . . Smiley Happy
bzak Aspirant
Closing the Flash update dialog DOES NOT WORK! HELP!
Highlighted
bzak Aspirant
Worthless equipment. Website is completely hosed, update flash player errors are not fixed. Tried closing the update prompt, no good, tried updating Flash, no good. Tried Chrome browser vs. Firefox, no good. Arlo is no longer useful to us after investring over $1,000.00 in cameras. Run, don't walk away from their products.
Model: VMB3000 | Arlo Base Station
Guru StephenB Guru
What browser are you using?
bzak Aspirant
Firefox. Finally figured it out, need to click "manage plug in" dialog and allow Flash. Can't Flash be eliminated?
johnlib Tutor
Thanks for the solution.  Icon on address bar says Manage Plug-In Use when you put mouse over it.  Click and allow.  icon jpg.JPG     icon1 jpg.JPG
murphykj Aspirant
Worked.  Thank you!  Have been trying to figure this out for a few days now.
gellis Aspirant
The solution of clicking on the adobe flash icon in the top left between the (i) and (lock) solved the problem. Click on the icon and allow adobe to open, then go back to your device and click on (Live). Problem solved.
Model: VMB4000 | Arlo Pro/Pro2 Base Station
