Adding an Arlo Pro to an Arlo HD base
  • 1 Reply
  • 3501 Views
pneffkell
I see several places that the arlo pro can be connected to an arlo hd base. From what I can find you don't get the alarm and you don't get local storage but do you get 2 way audio? I can't find anware that clearlys hows what features don't work on an Arlo pro when attached to the Arlo HD base station
Yes, you do....  I'm currently running / testing a PRO cam on the Arlo base.
There have been no issues to speake of and the audio worked fine on the PC, a little low on the iOS and very low on Android... the new sw was to fix the android low audio I believe. ( either way Netgear is/was aware of the problem )
