Removed device from my Iphone by mistake and now I'm trying to add it back to my phone but it says "discovering your device please wait" then it says no arlo device found. Internet and wi fi all connected ok
Message 1 of 3
1,765
I did and that didn’t do it. I did end up pushing the reset button with a paperclip and that did the trick. Resynced the cameras and all is good. Thank you for your suggestion
Message 3 of 3
1,720
Hi PVBJVB,
Did you push the sync button on your Base Station to see if the Arlo app is able to discover the device?
Message 2 of 3
1,733
Message 3 of 3
1,721
