  • 4417 Views
mjjones
Hi everyone
Does anyone know if you can add ARLO Pro camera's to an existing setup which already has multiple original ARLO cameras?  ie. does it work with the original base station?
Yes, Arlo Wire-Free cameras will sync with the Arlo Pro Base station. Arlo Pro cameras can also be synced to the Arlo Wire-Free base station.
For more information on Arlo Pro, see here: Arlo Pro The world’s first and only 100% wire-free, weatherproof, rechargeable HD smart security cam...
Robbiel
Will the older wire free camera work with proper basestation? I have the 2015 system and was thinking of upgrading to new system but still use the old camera with newer stuff
Yes, no problem. The old cameras will operate as before and will record to your USB drive attached to the base if you set that up.
