ARLO PRO
LOOKING TO BUY A ARLO PRO 3 CAMERA SET UP....CAN THE CAMERAS BE SET TO RECORD 24/7 WITH OUT HAVING TO HAVE MOTION TRIGGER THEM....ALSO WHAT TO LEAVE 1 CAM WIRED.....DOES THE BATTERY HAVE TO BE IN THE UNIT TO WORK. THANKS YALL.
No, you can't use Arlo for 24/7 recording. The closest you can get are the Q cameras with the CVR extra cost option.
