ARLO PRO time change
I currently set up my Alro Pro. I set up the wrong time zone and can't figure how to change the time zones. Please help me figure this out? Thanks
Go to settings in top rite next to log out then go to my devices then go to what ever name you changed your base station to "base" It will be your second down underneath base name and above flicker adjustment. Timezone ☺
Thank you I tried that earlier at work. I guess I have to be on the network to do it
Work networks frequently causeissues accessing the Arlo servers. Use the app on cell service.
