ARLO PRO push notifications
Turn on a push notification for one Arlo Pro camera, and set up a rule for that camera's activation to turn on four other cameras. Why does it send push notification if any of the other cameras in the rule are activated? Push is set for my front door camera only. If someone walks in my driveway the camera there sends a push that I did not ask for ??????
Seems like when you made the rule to activate the other cameras, the push is carried over...
Push is generally a global setting ; all or none
Have you tried emails?
I want to know right away when someone walks up to the front door. I might check an email the next day.
Certainly you can use emails for testing purposes.
Not sure what type of test I would be performing. And I am not sure I should bother with this since an email will not work for me. But thank you for your suggestion.
