ARLO PRO SOLAR PANEL concerns
  • 1 Reply
  • 2205 Views
Moses1979
Thinking to buy the Solar panel for my ARLO pro. I saw the latest announcement regarding the outdoor charger has safety issue. It appears the VMA4600 has the same way to connect to the camera. Is there any safety concern for VMA4600? Cheers.
None noted at this time.... I used one out in the rain for over a month, no issues. The plug has a slightly diff shape/taper.
THO, I also would if going in a permant location, use some sort of dielectric grease in the opening prior to plugging in the cable as an added sealant to prevent water intrusion
  Mind that it is unknown if this would void the warranty on the cam
