ARLO PRO - CAMS record all the time when triggered by motion despite schedule to not record
@JessicaP - I will test that tonight and let you know. Although, the geofencing feature is very important to me. Thanks. Jeff
@JessicaP - I turned off geofencing and just left it on Schedule and the system seemed to work properly per the schedule setting (without using the geofencing feature). I don't understand why geofencing is creating a conflict? Seems to be a glitch with the system. Do you have any suggestions?
Again, my trigger camera is always sensing motion when I'm at home and ignores the fact that I have a schedule set to only activate during certain hours.
Thanks. Jeff
Just FYI - I have no fix for you......
IMHO - geofencing just doesn't work well. It relies on cell tower triangulation, which depending on your location can be hit or miss or inaccurate at best. I was never able to get geofencing working on Arlo or SmartThings. I live in the country and the cell tower are few and far between.
Sounds to me like your phone, arlo, (whatever) isn't realizing your home and not switching the mode. Geofencing is what it is, not very good, imho.
Smartthings, Arlo pilot, and a smartthings arrival sensor is my setup now, and it works perfect. If you're into home automation, check out smartthings.
@pc2k17 - Thanks for your reply. Just an FYI that I also live in a somewhat rural area but geofencing works very well for me. I get notified once I'm home or leaving the area and Arlo always switches to the appropriate Home or Away mode. It is just that when I'm home, the Home mode doesn't follow the rules of the schedule. If I get home at 5:30 pm, and I switch to Home mode, my trigger cam shouldn't start recording my activity since the schedule says to start recording at 7:00 pm. I'd love the system if ONLY it worked as it is suppose to work. Jeff
