My 5 Arlo Pro Cameras send alerts & all work great.  They never drop out. But after several months of free cloud storage, the motion timeline is empty for an tire month & movement triggers no longer record motion in the cloud. How do I restore cloud storage for movement?
Solved my problem! Had smart settings for all 5 cameras set to "do nothing" if motion is detected!
Here's my sign, LOL!!
YES - you can set up one camera for motion detection and the others on record. Go to the "Security" setting on the Arlo App (Security is actually setting options on the Hub) - not the individual camera video settings. Choose SmartThings. There you will see full individual controls for each camera. I just verified this on my 5) Arlo Pro cameras / hub setup. Each camera can be set up independently to monitor motion, sound, record, send push notification or email notification - or any combination of these options.
Personal note: I turned off sound monitoring on these same settings because whenever a loud truck drove by, I received a push notification from each outdoor camera - this became very annoying!
						Apple HomeKit1
						Arlo Mobile App449
						Arlo Pro27
						Arlo Pro 21
						Arlo Pro 32
						Arlo Secure1
						Arlo Smart102
						Arlo Ultra1
						Arlo Web and Mobile Apps6
						Arlo Wire-Free10
						Before You Buy1,206
						Discovery1
						Features237
						Firmware1
						Firmware Release Notes119
						Hardware2
						IFTTT1
						IFTTT (If This Then That)48
						Installation1,430
						Installation & Upgrade1
						Online and Mobile Apps1,266
						Partner Integrations1
						Security1
						Service and Storage563
						Smart Subscription1
						SmartThings39
						Software & Apps1
						Troubleshooting7,335
						Videos1
