2 different ARLO PRO with same account but in different location recording
  • 1 Reply
  • 1475 Views
apt5020
I have two ARLO PRO with 6 cameras + 4 ARLO Q. Basically will I be able to do 7 days recording or is that limited only two 5 cameras per account? I want to monitor at two different location but with the same ARLO logon ID. Is this possible?
You'd need to be able to split the cameras into groups of 5 to utilize the free 7 day plan. That would involve a second base station since you have 6 wireless cameras, with up to 5 on one base and the remainder on the other.  The second base and associated cameras would need to be set up with a second account using a second email address and then using Settings, Grant Access from the second account to the first so all cameras show up in one login.  A bit of fiddling but not hard.
The real question is whether you can split the cameras up into groups of 5 reasonably. Note that they don't have to be on the same network or in the same location, just associated with a particular login.
