12V DC Power Supply for Arlo Pro Base Station
Instead of 120v AC for a power supply, like to have 12v DC for my boat/RV security....How to do it is the question.....wiring diagram is perfect !!!!
The base unit does run on 12vdc/1.5a now... It's a common coaxial plug with center positive
If you mean the cameras, then a simple auto usb adapter with 2a out will easily run the camera
Thanks for the info ......will try it out soon
