Compatibility question
  • 1 Reply
  • 1233 Views
Belizdr
I ordered Arlo Pro 5 wi fi Cameron. Which type of Smart Hub I could order to be compatible with my Cameron?  Regards, Belusic
Not sure whether you are getting the Pro 5 or Pro 6, since you posted in the Pro 6 forum area.
Either way, the Pro 5 and Pro 6 can both connect to your home wifi, so the smarthub is optional.  The main benefit of the smarthub is that it gives you the option of adding local storage.
As far as compatibilty goes, you can get either the VMB4540 or the VMB5000.
Note both of these cameras require a subscription to get cloud storage, and they are not supported in all countries.  It'd be helpful to know what country you are in, so we can let you know if you can install them in your location.
  • 1 Reply
  • 1234 Views
