pro 5s2k wireless internet password changed
  • 1 Reply
  • 56 Views
Roofus
My wireless password changed ..  it is all lower case words & .     when trying to update Arlo password to match it will not allow due to need Capt. and symbols..  is there anyway around this
I think you are confusing your Arlo password with your WiFi password.  Arlo does NOT require caps or symbols in the WiFi password.
One option you might consider is setting up the router to use the same network name and password as the old one.
