hi there just wondering if some one could tell me why my pro 5 camera is upside down when i go to view it on my phone or pc i set it up the correct way writing on camera is up the right way , the charging port is on the bottom . next thoughts ?
Go to the camera settings, Video Settings and check the Rotate Image 180 degrees to verify it's not set. Toggle it if needed.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
