Video has horizontal lines
Brought 2 Pro 5 cameras 3 months ago. One just started showing horizontal lines. Does anybody have any pointers about how to remove them?
Sounds like a hardware issue. If you have a subscription for them, use Settings, Support (Center) to select the camera model. Scroll down to Contacts to talk to official support.
andrewhunter,
You might try removing and reinserting the battery to the camera and test again to see if you still experience the same behavior. Also try testing the camera in a different location to see if you still experience the same results.
If neither of the options above work, I encourage you to reach out the support to further investigate the issue, as jguerdat mentions.
Same issue with ultra 2 4k Alfred’s fought to have it replaced and still the same issue 4 cameras and this is the only one with the issue in night mode did all their trouble shooting steps too. Worked great for 5 weeks now this. The replacement one out of the box does the same thing.
WHat have you tried? This tends to sound like a signal strength/quality issue to me.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
