Using same account in different continents (locations)
  • 1 Reply
  • 622 Views
Ebere
I have an account which I use for my family in USA. I bought many arlo camera which I plan to install in my  home in Nigeria. Can I use the same account for both installation. Secondarily, The account in Nigeria would be accessed by other relatives. How do I limit access to the one in Nigeria for relatives so they cannot access my camera in USA while using the same account. Thanks
You should be able to use the account created in the US to install the new cameras. However, you'd need to create a new location for them which will require a second subscription (one for each location) for cloud recordings.
You can use Settings, Shared Access to allow others to see only the cameras/locations you select.
