I'm sure it does not make a major difference, but this is more for my knowledge. Just wondering by turning off features I don't need, use, or want, does that help extend the battery life? For example, volume, microphone, etc. Or how about on Routine (Schedule). Camera is on. For example, nothing is happening or will happen between 7am to 7pm. Does it use more battery just be on "active" and ready on a Routine schedule?
The camera definitely uses less power when it is off and when it is disarmed. Disabling audio detection likely will help some. I don't think the mic itself or the volume of 2-way talk makes any difference.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
