We have the option to shape the Activity Zone. Does Arlo cameras work better with "square" shape zones? Or it does not matter? And I can go jagged in the exact coverage area. Just trying to make it "easier" for the camera to detect motion. I have not come across any issues with my current zone settings, so just wondering.
When the camera is on battery power, the activity zone is processed in the cloud, not the camera. The camera senses motion using a passive IR (PIR) sensor - not the image. When it triggers, it streams video to the Arlo Cloud, which will supress the recording and notification when it determines that the motion is outside the zone.
As far as going "jagged", you can do that, though you are limited to an 8-point polygon. I don't think the zone processing is all that precise, so I suggest leaving some margin around the area you want to exclude.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
