Is there a way to turn off the camera light (blue) from flashing everytime it detects movement?
That shouldn't be happening. The likely solution is to remove the camera from your account and add it back in. Did that work?
george1712,
As jguerdat mentioned already, a blinking blue LED is not an indication of motion detection. For more information on LED behavior, take a look here: https://kb.arlo.com/642/What-do-the-different-LED-behaviors-on-my-Arlo-camera-mean
Thank you for your response. I tried: restarting the camera, upgrading firmware, connecting to a different network, and removing it and adding back, but the blue light is still blinking for a few seconds when I approach it or if I make a sound. This happens irrespective if the system is armed or not.
It seems you've done the troubleshooting needed. Use Settings, Support (Center) to select your camera model. Scroll down to Contacts to start talking to official support.
Hi - I have not solved the problem, but I discovered that the blinking stops when I disconnect the camera from the USB power supply - not sure if this is a feature or a bug.
It would be a bug. It kinda sounds like the battery is fully charged but is right at the threshold where the blue LED would light up so toggles between off and on. It shouldn't do that so talking to official support may be needed for a possible RMA>
I have a Pro4 and a Pro5, both on USB power. The blue 100% charge LED remains on. The option to turn it off seems to have been removed from the App. I connect these cameras via Wifi, no hub.
Look in the camera settings and click on the top selection that shows the camera which is Device Info. In there use Indicator LED to turn off the LED when fully charged.
That button is no longer there
You didn't click on the TOP selection that shows the camera and whatever you've named it.
Got it... thanks...
You appear to be going into settings using the camera widget on the dashboard.
Go to the devices screen, and get into the settings that way. You'll find many other options there.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
