Pro5 and ASUS Wi Fi Mesh
  • 1 Reply
  • 1204 Views
R113770
Trying to setup my existing Arlo Pro 5S 2K cameras with a new Wi Fi Mesh System and it is proving to be bloody difficult.
I have an old base station that is not compatible with the Pro 5 and prior to getting the new Wi Fi Mesh System my cameras were linked straight to my Wi Fi Router and they worked fine.
I am considering buying a new Smart Hub to link the cameras to that instead of the Mesh System.
Any suggestions or feedback.
Generally the easiest path is to set up the new wifi to use the same network name and password as the old did.  Then all your devices (including the cameras) will just connect.
If the camera is still in your account, you could try that.
If you need to reinstall - have you tried doing this on both the phone and a PC (my.arlo.com)?
