Pro 5S 2k - Able to connect one camera but "cannot find" other 3.
I am so frustrated and annoyed. I have had the Arlo essentials for years. I recently purchased the 5S 2k's and have had nothing but problems connecting them. I even purchased a new Modem and Router.
I have disconnected all of my old cameras and the home base and have tried adding devices. After about 2 hours, I was finally able to add one camera.... but alas, 3 hours later, none of the other 3 can be detected. Do the whole process, logging into wifi, getting blue blinking light, getting chime... and nothing!
I have tried taking the battery out and starting again... NOPE!
I have tried the resent (holding button down for 15 seconds until flashes orangeish and then blue again... NOPE!
I am hating Arlo and sorry I didn't buy Ring. Although I may just return these and go the Ring route, unless someone can give me some constructive assistance.
THANKS
Can you provide which basestation that you have?
We disconnected the base station altogether, so we have added the 1 camera through Wifi, and have attempted the 3 others the same way.
I reached out to support regarding the cameras that will not onboard onto the account. Support will be reaching out to you as soon as possible.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
