Pro 5S 2K will not connect
Battery is on full charge, the camera was working fine for a week then went offline. I removed the camera from the app and tried to re-install. I've held down the sync button for 15s and longer with no result. The camera blinks once orange and that's all. I've left the camera overnight with battery out, tried to sync again with unfortunately the same result. I don't have a base station, the wireless coverage is excellent. What's this camera's issue?
I'd wager it's a dead battery. You can swap batteries around if you have multiple cameras to prove this. If so, try this FAQ. The key is to plug in and unplug multiple times to get enough charge into the battery to allow it to charge properly.
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
It's been plugged in all night and still the same 1 orange flash every once in a while. This is the 2nd camera as the 1st was defective. Do i have another defective unit?
But did you use the plug/unplug several times procedure? Just leaving it plugged in won't work.
That's just ridiculous and an unrealistic expectation. Returned fornfill refund.
Great looking paper weight, nothing more.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
