Pro 5 garbled video
  • 6 Replies
  • 1628 Views
Nem
I have been having an issue with my cameras since I put them online back in Dec 24.  All three will randomly just start recording a red/pink garbled video.  The only way to fix is to reboot the camera from the app.  Has anyone else experienced this issue and how did you fix it.
6 REPLIES 6
GeneralMeow
A few of us here have the exact same issue.  The only remedy is to reboot it.  Happens to me once a week on 2 different Pro5's.
Nem
I tried reaching out to support and their only solution was factory reset and delete from account and add them back.  I only have this issue with my pro 5s cameras.  The other two cameras and door bell don't have the issue
GeneralMeow
A factory reset wont help.
Yes, only the Pro5's seem to have this issue.  All other cams might have garbled video for a second but recover quickly.
ShayneS
Does this symptom still occur if you bring the camera closer to your router or Smart Hub?
Nem
All three cameras are less then 20ft from the wireless router.  They are all connected to hard-line power as well.   These cameras are in the exact same location as my previous arlo cameras that were upgraded to the pro
ShayneS
Please reach out to the Support Team to further investigate this symptom you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to the Profile icon > Support Center > Select device > contact
