Pro 5 - Not Charging
Hello -
One of my Pro 5 cameras isn’t charging. The contacts are clean, and I swapped out original charger and cable with ones that I know work (because I just used it to charge another camera successfully). The camera’s blue light comes on while connected to the power source indicating the camera is receiving power.
i figure the next step is swapping out batteries, but it’s going to be a pain because it’s mounted up so high. Any additional suggestions before I get out the ladder?
Thank you
Hi @user530717
When did you purchase this device or battery that's being used with the device? By what you described, it sounds like the battery may be faulty. The best way to troubleshoot this would be to swap batteries with another camera if possible to see if it charges.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
