PRO5S Recording stops after x hours.
Hi,
I have an issue with my new PRO5S will record, and then stop after a few hours. The IR dots are on, but it does not store recordings. The app also shows movement, but no recording. I cannot open the live stream either.
If I reconnect the power, it will start recording right away and be accessible, but again, a few hours later it will stop.. then I can repeat the power trick, and it will work for a few hours again..
Full signal strength, and not outage in signal. 9 other devices works flawlessly.
Br,
Martin
Have you tried to do a full reset on the Pro 5S and then add it back onto the account to see if that changes the behavior you are seeing?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
