New Zealand
  • 6 Replies
  • 1100 Views
Ian5019
I have a camera system involving 2 Essential Spot Light cameras and 1 Pro 5 camera. I record activity locally using a Smart Hub. The Smart Hub only shows the 2 Essential Spot Light cameras as being connected. Even though I get notification of activations from the Pro 5 nothing is recorded on the Smart Hub. How can I fix this?
Silly question but is the Pro 5 also synced to the hub? If it's connected to your WiFi, no recordings passes through the hub so can't be recorded there.
6 REPLIES 6
Ian5019
Hi Jguerdat.  Not a silly question. A check of the cameras settings shows it is connected to wifi. I followed the process to sync it to the hub but it still shows connected to wifi. Any advice on how I can fix the problem would be really appreciated.
Did you try removing it from your account, and then adding it back?
Ian5019
Thanks Stephan. I'll try that and let you know!
Ian5019
Thanks so much. All sorted. I now realize how it happened. The Pro camera came with 6 mth free cloud storage. At the end of the time I didn't realize I had to change the storage setting from wifi to hub. Lesson learned! Thanks again.
Ian5019
Thanks for the advice. All sorted and no tears or tantrums.
