My outside camera went off 15 times in 35 mins and kept showing Sound Detected ,How do I stop this
This has done this once the night before at around the same time but last nite was insane and my neighbours are not happy
@cushy wrote:
Sound Detected ,How do I stop it
Edit the mode you are using at night. Go into the rule for the camera and turn off audio detection.
Or alternatively change the threshold in the "default mode settings" in the camera settings.
If the issue with the neighbors is the spotlight, then you could also turn off the spotlight and just use Nightvision.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
