With multi cameras how to have some set for Armed away and some standby or other combination. Right now all my cameras can only have one settings, I need to be able to have some in one mode and some in another at the same location (indoor and outdoor). Do I need to remoce camera from Home and assign them to another location call indoor?
@AG400 wrote:
Do I need to remove camera from Home and assign them to another location call indoor?
If you do that, you will need a second subscription.
While you cannot add more modes, you can modify the three you have. If a camera has no rule in a mode, then it is automatically disarmed when the system is in that mode.
If you only need one combination with only some cameras armed, then use "Arm Home" for that. If you need two combinations, then I suggest modifying "Standby" as well (adding rules). Then turn off cameras using the video settings as needed.
Hopefully Arlo is working at bringing back custom modes.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
