Motion detection doesn’t work
All 4 Pro 5S cameras don’t detect motion-even directly in front of them. When testing motion, the amber light will come on but the cameras don’t detect it when enabled. Even when accessing the live feeds, it takes up to 10 seconds for the live view. They are placed 50-60 feet from the hub and there are no obstacles (other than the glass of a window) between them. Please help me use my cameras.
I have a premium subscription and my cameras are fully charged and linked to the smart hub. I’ve restarted them several times but the issues remain.
Thank you!
There was a very long thread about that: https://community.arlo.com/t5/Arlo-Pro-5S-2K/Arlo-Pro-5S-missing-events-taking-snapshots-Pro-4-in-sa...
I don't know if the problem was resolved in the end or not.
However, my Pro 2 and Ultra also have problems with motion detection, though probably not as bad as that of Pro 5.
I have two suggestions.
First, I suggest you double-check that the cameras are armed in the mode you are using. If they are, then increase the motion sensitivity to 100 for now.
Second, I suggest moving one of the cameras closer to the smarthub as a test, and see if the motion detection (and the livestreaming lag) improves. Ideally put it in the same room as the smarthub (6-10 feet away from it).
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
