How to record with 5 devices?
Hi guys I purchased a 3-pack 5s some months ago. Now I’ve added one Ultra 2 and the VMB5000 hub. Seemlessly I can add the Ultra and record/store videos on the hub. I’ve troed to remove the 5s from my installation and install it again and sync with the hub. It has synced, and under the hubs profile it says it is synced. But when trying to record on the 5s it says it is a “Premium feature - go to arlos webpage to admin your plans”. I seem to find the 5s should work with the hub, so the question is, How do I route storage to the hub instead of in the Cloud? Best Thomas
2 things:
1) in the hub's settings, go to Storage Settings and set it up to use a micro SD card. Once configured, you would use Storage Settings to view the locally recorded videos via the app.
2) If you have activity zones defined, you need a subscription to clear those messages. Clear the zones to remove the message.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
