How to change the timezone?
Hi all
after setting up camera I’ve realised I’ve set one time zone! How do I change this please?
@Loglifter wrote:after setting up camera I’ve realised I’ve set one time zone! How do I change this please?
If you entered your address when you set up the location, then the Arlo app sets to time zone for you (and you cannot change it).
You could try Arlo support. Or you could try removing the camera from the account, creating a new location (NOT setting an address), and adding the camera back. Then you will be able to set the time zone manually in the app.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
