Charging a pro 5s camera
My battery is dead but my pro 5s camera flashes blue and amber. What is wrong?
Usually flashing red/blue is an indication that the camera is trying to update but it has likely failed if it is continuous.
It is unlikely to be recoverable so check your warranty status for the camera using the arlo mobile app, settings/support/camera.
Have you reinserted the battery? Do you have another camera to swap batteries around? Is the alternating LED color when plugged into the charger or when battery-only?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
