Cant install camera pro 5S 2k in Israel
  • 1 Reply
  • 867 Views
barakmanager
Hi, I bought the camera on USA, install the app and create it in Israel. and the app not give the option for adding Pro 5S 2k, tried with VPN, it didnt work as well, any help?
The account must be created in a country that is supported (such as the US or EU). You'd either need to be in that country or use a VPN to a server in that country to do this. You can then set up the system, using a credit card from that same country. Once set up, you don't need the VPN.
